disable ospfv3
disable ospfv3
Description
Disables OSPFv3 for the router.
Syntax Description
Default
N/A.
Usage Guidelines
None.
The following command disables OSPFv3 for the router:
disable ospfv3
Platform Availability
This command is available on platforms with an Advanced Edge or Core license as described in the Switch Engine v33.1.1 Licensing Guide document.
